BobnLesley
I'm sure I'm not the only person whose starter simply 'clicks' on occasion; I reckoned the cause was voltage drop in the long cables to the start-switches between the Solenoid's A & B terminals? When I checked for this I was surprised to discover that the worst offenders were the key & push-button switches themselves, rather than the cables.
My 'plan' to cure the problem is two-fold: First I hope to renew the switches, so question 1 is - rather than a one-turn switch and push-button, is there anything to stop me wiring in a two-position sprung switch (like a car ignition) instead. Secondly, it strikes me that rather than send the 30 amp starting-current from engine-bay to the control panel and then back again, I could put a short heavy gauge wire via a relay, between the solenoids A & B terminals and just have the cables to/from the control panel carrying that relay's energising power (a lot less amps through a small cable). Am I correct in my thinking and can you foresee any problems with the idea?
