Yanmar spares
Dave_Rolfe
7 Mar 2003
Devon
I have just been quoted £2.62 + vat for one copper sump drain plug washer for a Yanmar 1GM10 engine. I know that engines parts are pricey but this seems excessive.
Does anyone out there know of a suitable substitute from another source that can be used to ensure a good seal around the plug.
As an aside does anyone also know a substitute for the oil filter for the same engine as again, these seem expensive for a fairly ordinary item.
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
As regards the oil filter I would stick to the Yanmar one as we once compared the filtering area of an o.e. one, in this case Ducati to an alternative and the o.e. one actually had about 3 times the filtering area.For the difference in cost it seems sensible IMHO.Copper washers can be picked up at most automotive suppliers.
Al.
<hr width=100% size=1>No dear,the water goes in the other one.
Gunfleet
1 Jan 2002
Orwell
Hi Dave,
I thought you might like to know for future reference according to the manufacturer's manual Yanmar 1GM10s are not meant to be drained through the sump. And you're dead right, their parts are horrifically expensive.
Dave_Rolfe
7 Mar 2003
Devon
Thanks John. Yes I had read that the oil should be removed through the dipstick hole. I don't know about you but I like to think that when I drain the oil any small bits of debris are also removed which I feel does not happen when the oil is sucked out.
Surely if there is a drain plug to the sump it is there to be used for just this purpose.
Stemar
12 Sep 2001
Isn't the reason for dipstick oil changes is that there isn't room to put a can underneath the sump on most boats? I saw engines at SIBS that have a pump attached to the sump drain so one can pump it out from there, which does seem like a good idea.
As for your solid gold copper washer, if you hold the old one in an old pair of pliers and heat it to cherry red, then drop it into cold water, you'll soften it so it can be reused. Otherwise, take it into a back street garage and they'll probably give you a new one that will fit from their oddments box
masterofnone
24 Feb 2004
Newhaven. East Sussex
If someone would repeat the advice posted before about alternative filters for the 1gm10, and also advise how I can bookmark the advice, to retain for future use, I should be very grateful.
bendyone
19 Jan 2003
Oxford
Crosland 672 or Purflux LS489A according to the cross-refs for the oil filter. just got one £4.25
duncan
Home mid Kent - Boat @ Poole
then click on favorite link at the top of the thread.
when you go into your user option in the future you can access a list of your favorite threads like a mini personal forum.
<hr width=100% size=1>madesco madidum ..../forums/images/icons/smile.gif
Rohorn
3 Oct 2003
Paros, Greece
Hi...with normal copper either way will anneal it sufficiently, quenching is a lot quicker, and gives a more even effect. For bigger items, leaving it around to cool can leave it a bit patchy as some bits of it cool quicker than other bits.....but either way is well sufficient in the case of a sump-plug washer!
Also on the 1GM10, you change the filter every third oil change, according to Yanmar...but that had better be the correct original spec filter...
Cheers...R
nealeb
4 May 2004
One reason for not draining via the sump plug on a 1GM is that when you take it out you end up with a handful of odd bits of strainer, spring and things. Note well the order in which they come out! I usually did it this way, though, and had no problems. Fortunately there was just enough room for a drain tray.
Really confused me when I changed boats and ended up with a 3GM - couldn't find a drain plug anywhere! There isn't one...
