joliette
I have a Yanmar 30GMF fitted with a KM8P gearbox, which appears to be developing a fault. When I select ahead the prop shaft doesn't always engage immediately. Sometimes there is a gap of a second, followed by a rattle before it engages. This doesn't happen when the engine is cold but has occured a few times when the engine has had a good run for at least 20 - 30 mins. It doesn't happen when I select astern. I've changed the gearbox oil and checked the selector mechanism but this has not made a difference.
Does anyone have any experience of this problem?
Is this likely to be due to some wear developing in the clutch and causing it to slip? Are these boxes fitted with a cone type clutch? Is this easy to replace, without any special tools? Where is a good source for parts and a workshop manual?
Thanks!
Thanks!
