capnsensible
Ive got a boat with a 3GM Yanmar unit plus a standard gearbox.
This has been getting increasingly rattly over the past couple of months, but only in ahead and up to about 1200 revs, after that the rattle and vibration smoothes out.
Anyone else had a similar problem??
Prop is ok, cutlass bearing replaced in January, alignment good. Only happens slow speed ahead.
Took the gearbox off today, plus driveplate. Local agent is doing a bit of tooth sucking so thought I would ask here.
Driveplate looks like black sikaflex has been put on the springs, seems a bit odd. Small engine oil leak into bell housing but drive plate dry.
Drive plate is £450, gearbox over three flippin grand!
Any tips much appreciated, ta in advance.
CS
CS
