VicS
What would be the consequence of one brush making a good contact and the other not?
There would be a poor connection to the field coil, whichever brush it was.
Many of us have found that the biggest glitch in every electrical system is the connections, and always the first and easiest to check.
Wrong!Glowing faintly will always be a bad earth, never a brush.
A brush fault will always be lamp on or lamp off never glowing.
What causes people to think it is caused by the brushes is the fact that to inspect the brushes, they remove the battery live terminal (or earth terminal) remove the alternator. The brushes are then inspected, repaired or changed and everything is returned to the engine and the battery terminals are then reconnected.
Everything is good, no glowing lamp and it is therefore assumed that the brushes we at fault when in fact disturbing and reconnecting battery terminals or alternator body has in fact effected a cure.![]()
VicWhy?
Explain your reasons for saying it's wrong.
Vic
happy new year, am sure you have noticed the new years resolution?
"Glowing faintly will always be a bad earth, never a brush"
Thats whats wrong. I dont have to explain it to you, youve already posted similar ideas to mine so I know you understand how they work.
Ive added my years of experience fixing the things. My real time experience tells me, light slightly glowing then going out when revved, then it steadily gets worse till the slightly glowing light wont go out when revved is a steady deterioration of the brushes. No input means no output. Simple really!
Stu
Vic asked me nicely to explain, I answered in the same vein.I think Vic knew this as Vic and I were getting there through my questioning of:
Quote:
Originally posted by Talulah
Understood but would there be any physical indications that this may be happening without dismantling the alternator?
etc
Stu
He was wrongI was just trying to be subtle. Instead of "Wrong".
He was wrong
"Glowing faintly will always be a bad earth, never a brush.
A brush fault will always be lamp on or lamp off never glowing"
I know that, you know that, Vic knows that, a few others know that, so whats wrong with saying that?
Stu
Hmm spose so,Just different styles. LOL.
.I've had a look on the intarwebs and found
http://www.startermotor-alternator-s...nator-21-c.asp
and
http://www.trickettmarineproducts.co...ternators.html
which seems to be not too unreasonable
In view of all the suggestion and comments made it would be nice if the OP would kindly post the results of the fault, one can learn a lot from the findings. Thanks.
This whole post has been one of the best I have ever read here. Shorn of social chat it should be published in PBO as is - worth more than hours sitting in electronics classrooms.
Thanks guys!
PWG
