Ana
New Member
Hi!
Bought a cheap torque wrench. Result: it got stuck and I have tightened the cylinder head bolts too much!
So, what should I do?
Engine: 1-cylinder Yanmar YSM12 y 1980, the cylinder head is massive cast iron piece of art. I bet it is not the most sensitive cylinder head.
I had a short 1 minute test run with the engine, it runs all right. But what happens when it gets warm? (The engine is converted to fresh water cooling)
As I was tightening the bolts (to 134 Nm or 13,6 kg/m), I noticed that the bolts got tighter and tighter and the wrench did not tick. I did not tighten with all I could give, but I realised they were really tight (the wrench is 45 cm long).
So, should I let it be and believe that the tolerances in that primitive machine can handle that. I bet that over the years many mechanics all over the world have tightened head bolts with the gut feeling.
Or should I loosen the bolts? Then I probably should change the head gasket too...
