SampoSam
So finally had the fuel injection pump re-furbed which had a worn diaphragm and some lose part that was letting too much fuel through. This has helped to get to around 20-22 knots using trim tabs ( from 11) flat out but still hard to get on the plane so still not quite right so still checking. As the tacho is the original for a petrol engine and i am running a diesel ( Yanmar 240 i need to check i am getting the correct rpm - flat out says 4,200 but heard there is a mechanical cut out at around 3,400 so obviously not right ?. I feel the boat is always aft heavy and was thinking should try it by putting some ballast in the bow end ?
Any comments gratefully accepted..- 6 months later and ££££ out of pocket still not fully resolved
