stiknstring
Although I have this 110hp lump installed in my sailing boat, I thought the best people to approach over my constant engine problems were probably here on the Motor Boat site. For the past three years, since I brought the boat down to the Med, I have had the same problem : After any long passage under power, when I reach the destination and need to slow the boat down, the engine responds to a reduction in revs by cutting out completely. Today was just another example coming into the marina at El Arenal in Mallorca. The strange thing today was that I could get the engine running again (albeit a little reluctantly) and it would then engage into reverse but then die out when I put it in forward gear.
I have over the years had the gearbox removed and a new clutch put in, changed the volume of air that comes into the engine compartment (suggestion being that the original blower was too small for this larger engine and the heat in the Med might have been a factor) and last year, I had an engineer from the UK, who I much respect, fly down to the boat in Valencia to troubleshoot. He found that I had been running the engine at too low revs (1800-2200) and as a result the turbocharger had coked up. After a lot of work, he managed to clear the carbon deposits and last year the engine worked like a dream. As I said, this year (today), after the first passage (151 NM), the same problem occurred.
Have any of you had the same issues? Does this look like a recurrence of the coking problem (I have since run the engine at the recommended 2500 RPM), is it another gearbox issue, fuel filters clogged (I discount this one but it was suggested today).
I am tearing my hair out on this one, and yet I am sure there has to be a relatively simple (if expensive!) solution.
Grateful for any suggestions/comments
many thanks in anticipation. Alan
Read more at http://www.ybw.com/forums/showthrea...-what-are-we-missing-here#otP1fSGRZ2ljexjE.99
