mrangry
I have a Yanmar 4JH2E (1992) and found that the alternator isn't charging. I believe it is an 80 amp Hitachi unit, but cant see any model number, just Hitachi on the casing.
It has a heavy live cable going to the unswitched side of the engine isolator and a heavy black cable earthed onto the engine block. There are also two spade terminals, one of which I believe is a charge warning lamp but unsure of the other. I dont have a charge warning lamp and nether of these two terminals were wired when I got the boat. There is also a wire coming from the side of the casing which I think is for a tachometer. This is unused as the engine has a sender for this.
I am getting 12.6 volts across the live and neg terminals with the engine both off and when running indicating the alternator is not charging.
Looking online I am wondering should one of the spade terminals be an ignition live feed? Does the alternator require this for it to charge?
