Twister_Ken
On Snowbird the raw water cooling seacock is a small tap, starboard side on the top of the saildrive unit. It takes many turns to close (20?). I 'exercised' it yesterday and found that it would turn about three times from open towards closed then jam. Judicious use of controlled violence finally got it fully closed (levering it with a small ring spanner around the handle, advancing it about a quarter turn, then backing off and doing it again), after which it opened and closed relatively easily. Applied some waterproof grease externally (have I got the last tub of Duckham's Keenol extant?), crossed my fingers and hoped the problem had gone away.
Has anyone with a similar set-up had a similar problem, and if so, did you ever find the cause?
