benjy1966
New Member
Ahoy All,
If you're thinking about buying a new Yanmar 3YM engine think again. This engine has issues and I'm not alone.
In just 4 years it has let me down once a year on average. Two heat exchangers that started leaking. Yanmar said that my experience was unique but a quick search on line will show that others have had similar problems. The problem is because Yanmar keep cutting corners and using manufacturing techniques that are cheap, such as pressing in a tube rather than making a thread. At least with a threaded pipe, it can be removed and re sealed but once a pressed in pipe starts leaking you need to change the entire heat exchanger. Cost about £2000.
The cast iron exhaust risers come from a 40 year old Yanmar engine and are so restrictive that it blocked with soot after just three years and had to be replaced. Cost £500. I was lucky, one chap I read about had to pay £5000 to have the engine completely rebuilt as the increased back pressure sent carbon into his oil which acted like cutting paste.
The latest problem concerns the Johnson Seawater Pump which started leaking so badly the engine was rendered unusable. Just the shaft and seal cost another £200. So all in all, including unscheduled stops in marinas and parts I've had to buy I would say that this engine has cost me well over £3000 in just 4 years. Not to mention the stress trying to get any sense out of Yanmar.
The worst of it is Yanmar's attitude which is lamentable. They just don't care. I won't be buying another Yanmar that's for sure. It's my belief that have cut too many corners trying to be competitive. More fool them.
Benjy Yanmar 3YM20
Benjy Yanmar 3YM20
