garvellachs
Our elderly Yanmar 3HM is leaking coolant slightly from the area around the head gasket edge on the inlet manifold side. It has only done 900 hours but dates from 1984 and was raw water cooled until 2008. I fitted a Martec fresh water cooling conversion.
I suppose I could put up with it if I knew it wasn't going to get worse, but it's messy, and it's annoying to have to top up the coolant regularly.
So the question: if I take the head off and try to sort out the leak what might I find? Could this be a corrosion problem - do 3HMs or 3GMs (they are similar) corrode at the head/block joint? Is it likely to be fixable by skimming the head lightly perhaps?
If corrosion is unlikely to be the culprit, I would hope that skimming the head (if necessary) and a new gasket should fix it?
Otherwise the engine runs starts and runs well, no smoke to speak of, stable temperature, coolant stays clean.
Thanks for any advice from anyone who's been there or thereabouts.
