sebastiannr
Hi there,
I have extremely excessive belt ware (both water pump belt and alternator belt) on my Yanmar 3GM30F. The belts need tightening at least every 5-10 engine hours and the entire area in the engine room around the belts is covered in black dust from the belts. I know that my father was having this problem (I recently inherited the boat from him), but despite having worked as a marine engineer he couldn't figure out the cause of the problem. I have used both the correct 'thick' belt that rests on the sides and not the bottom of the belt and the thinner type of belt that seems to rest on the bottom of the wheels, the problem persists in both cases. I apply generous amounts of belt dressing to stop slippage, but that's obviously no solution.
If anyone has any ideas as to the cause of this problem, or even just a temporary solution, it would be much appreciated as I'm in the Ionian and am having to motor far more than I would like!
Many thanks,
Seb.
Many thanks,
Seb.
