CliffordGuernsey
I had installed in my 44ft Ambassador Italcraft twin Yanmar engines costing some £41,000. In 146 hours and 315 hours both engines destroyed themselves when the diesel injection pump seized allowing free flow of fuel. The pistons hit the valves writing off both engines. The independent pump engineers say the pump relies on the diesel for lubrication. In both instances the fuel was analysed and the viscosity was normal. This suggests the injection pump is either not fit for purpose or the pumps were faulty. Has anyone else had a similar problem with this engine?
Has anyone come up with an approved additive that will increase the viscosity of the fuel passing through the Yanmar injection pump to solve this problem.
Yanmar paid for the first engine to be replaced but are not interested in contributing to the second engine as it is out of warranty! At 315 hours it is hardly run in. Anyone buying a new engine needs to consider the manufacturer's attitude when things go drastically wrong. I find myself on average needing to replace a Yanmar engine every 150 hours. Expressed another way costing me £130 per running hour!!!
