xeitosaphil
I think I need to replace my mounts, ( or so the Surveyor said on the sea trial survey ) due to excessive sideways movement. The propshaft oscillates at about 1800rpm. The engine is coming out next week as I want to work on the engine compartment so I should be able to see if the mounts have gone? or whether it is something else, possibly bent Shaft
( probably not as it is 1" S/S and only 1mtr long ), also prop balance, misalignment or cutlass? I intend to replace the cutlass as a matter of course anyway and also considered replacing the mounts while I was at it. I also plan to draw the shaft and have it checked for true, but if I need to replace the mounts, the cost of yanmar replacements ( £600.00 Quoted ) has made me look for other options. It has been suggested to me that I try R&D Super Mounts? ( which are Shear mounts )
I contacted them and they say they have had some good results with yanmar engines with either Compression Mounts or Shear mounts
The cost of 4 mounts complete with flexible coupling is only £200.00, which is a big difference?
Does anybody on the forum have any first hand knowledge of these mounts, or fitted them to a 2GM20?
I have looked at several threads on 2gm20 but don't seem to be able to find anybody that has fitted alternative mounts, with long term results?
I would be interested to hear of any comments or results, so I am to be prepared for the prospect of mounting replacement which I think is going to be on the cards anyway.
