Ardenfour
as per title - when sailing do I lock the prop in gear or let it spin? Would need to be in reverse, it still seems to turn in forward. I seem to lose a fraction of a knot when the prop is locked.
PRV - do you still have access to that guidance note from Yanmar?
At the risk of returning to an age old argument, the least drag from a fixed blade propeller is when it is spinning unless it is 2-bladed with a skeg to tuck it behind when locked is better. The KM2P gearbox has been reported to jam when reverse is used to lock it but mine certainly doesn't. However, the Yanmar advice is to let it spin.
That's interesting, and counter to what I've been told - My belief is that a fixed prop generates less drag than a spinning one. As a simple experiment, pull a child's "windmill" through the air with the blades spinning, then do the same with the blades locked still...there's far less resistance with the blades still. I've always sailed with the prop locked in reverse, and never had any issues.
It has been proved over and over again that a freewheeling prop generates less drag than a fixed one. A student did a PhD thesis on it at Strathclyde Uni, Maine Sail has done it using a catamaran with a prop mounted on it and measuring the drag and PBO had somebody do it again about two years ago.
The KMP gearbox does lock in reverse, or at least it becomes impossible to move the lever, but it seems to do no harm to start the engine with it in gear and then go into forward. We have noticed a strange phenomenon of this box. If we apply reverse immediately to start our Brunton feathering it will arrest the shaft. If we forget and sail for a while with the prop rotating, applying reverse does not arrest the shaft but applying forward does. Applying forward immediately does not arrest it.
It has been proved over and over again that a freewheeling prop generates less drag than a fixed one. A student did a PhD thesis on it at Strathclyde Uni, .......
It has always intrigued me that the great Sir Robin raced around the world with a prop from a non functioning engine, spinning merrily away.
It has always intrigued me that the great Sir Robin raced around the world with a prop from a non functioning engine, spinning merrily away. I wonder how much faster he would have been without it.
I muse on that fact every time that I start to think about splashing out beer money on a folding prop. ;-)
