LP1
Hi all, I have bought an Achilles 24 with a yanmar 1gm10 shoehorned into her!
Doing some research I decided to replace the exhaust elbow with a stainless steel one, I removed the old one to find a heavily choked up exhaust outlet, but what is concerning me is the presence to little brown droplets just visible in the picture, but more present in the elbow itself.
What is this likely to be? The elbow is ok and has not failed. Do I need to be worried about possible water in the the head?
Also, when I took the impeller cover off (outside was heavily covered in verdigris due to gasket failure) there was a lot of calcification in the housing and pipework that you can see on the towel. I am now concerned that the water channels in the head could be quite blocked.
The main problem is that the clearance between the rocker cover and underside of the cockpit is about 5-10mm, so I would have to take the engine out to get the head off.
I was also thinking of fitting a centaflex CF-M-127 on the back of the gearbox if I do take it out to solve any possible alignment problems.
Ok, so there is lots to think about, it's my first post so hello to all, and I would appreciate your thoughts on anything I have mentioned here.
Regards
Lee.
