pagoda
We have just had this same issues, but with a bit of northen engineering it works.
the nut is a 10mm so if you get a 9mm socket and extension and hammer this onto the corroded head (use alot of force) it dislodges the rust and frees the bolt then with alot of force into the thread (not torque) it shoudl pop off,
the others came off using some nedle nosed molegrips.
after a few hours swearing ours came loose this way
Done that method a few times. Especially useful if there is a thin skin of even rust on a bolt head = 1 or 2 sizes below normal.
It gets very scary doing this on anything under 6mm. They tend to behave like Cheddar cheese ...
