richardabeattie
It's not just the 24mm metric ring spanner, its the 16 oz imperial hammer you tap it with to shock it into moving. And I still have not managed to crack the block.
Yes.
Merlin's external alternator regulator box has an LED on it marked "RTFM". With a straight face, they claim that it's the "Real Time Fault Management" indicator
Was 'full' the edited version?
Not Yanmar though, no anodes in the 'F' models.
Surely though," Read the full manual," is what RTFM stands for.
Although there is an anode shown at the end of this link Vyv - http://psyberspace.com.au/yanmar/anatomy.htm
Although perhaps you are counting that as a saildrive anode rather than a 3YM30F anode?
Incidentally, why does it say on it "Don't remove while boat in water"? Presumably the anode sticks into the sea water stream which comes up through the saildrive leg and is presumably before the seacock otherwise you could just close the seacock to change it. I wonder why they didn't put the anode after the seacock?
I haven't changed mine myself yet although I will do it next time.
Richard
Richard
My reply to VicS' post was referring to the heat exchanger. All the anodes shown in the link (quite a good one, incidentally) are on the saildrive, not the engine. I cannot answer your question, I have a shaft drive and have not really studied saildrives other than about their corrosion.
