Yanamar Scare
jfkal
17 Aug 2001
Singapore
My Yanmar had trouble starting. After some cranking the engine came alive and thick greyish blackish smoke out of the engine compartment. I rushed down, shut off, got the fire extinguisher ready. But nothing wrong and the smoke cleared. Thought the exhaust pipe might havbe come off. Found nothing wrong, started the engine again and everything was fine. Where did the mistery smoke come from??
brian_neale
5 Jul 2001
Winchester, UK
My Yanmar 1GM appeared to have started running backwards once - I was trying to start it on the handle and it bounced back from compression and seemed to fire a few times going the wrong way. Lots of smoke from the air filter inlet until I stopped it with a quick lunge at the stop control. Never done it since, but my starting technique has improved since then!
ccscott49
7 Sep 2001
Almost definitely started momentarilly backwards. happens with diesels, even known to happen with petrol engines when switched off.
jfkal
17 Aug 2001
Singapore
That sounds like a plausible explanation. Lucky I did not draw water though. After that incident the waterpump started making squeaking sounds. Indicates that the impeller has been run "backwards". Better change it soon.
Joerg
brian_neale
5 Jul 2001
Winchester, UK
Why does reverse running hurt impeller?
Not sure that running an impeller backwards for a short time will do any harm. The books always talk about putting new impellers in place with the vanes going the right way, but have you ever looked at what happens if you do not? When replacing my 1GM impeller once, I greased the vanes as per usual but had more trouble than usual getting the vanes to point the right way. So I put it in anyway, and slowly turned the engine over with the handle before putting the lid on the pump. The vanes had flipped within a single revolution. Since then, I have not worried about it. Impellers parting company from the bronze bush are more common on my boat (done it twice now).
ccscott49
7 Sep 2001
Re: Why does reverse running hurt impeller?
Normally, when the impellor has been run for a while, it takes up the shape of the direction of rotation, when you run it backwards for a while after that, it often self destructs, especially if its been in there a while. Had the bronze bush seperation a few times, but only on small impellors, genny etc and on a few small yanmars.
brian_neale
5 Jul 2001
Winchester, UK
Good point about old impellers. Certainly take on a permanent set if left in the pump over winter! However, if the impeller is getting that brittle, probably time to change it anyway?
How often should you change an impeller?
