Bob_Ranft
Got a Yanmar 3YM30 with just under 90 hours on the clock. Starts well, basically instantaneous, even in depth of winter, tick over is smooth, but vibration above 1200 rpm until say 1900 rpm. Above 1900 rpm engine runs smooth all the way up to 3600 rpm under load. Vibration is worse when throttling back, sometimes sounds like engine is on two cylinders.
Had cylinder head off, checked for flatness, pressure tested, injectors checked, valves lapped in etc. Problem still the same. Next step I think is to look at the fuel pump, or fuel pump timing.
Anyone out there with a Yanmar 3YM30 with similar vibration, or one that runs smooth between 1200 and 1900 rpm.
Thanks in advance.
Bob
Thanks in advance.
Bob
