Yamaha 6hp 2 stroke shift rod clamp replacement
Housecat
New Member
30 Aug 2021
Hello all. I've been learning a lot about mechanical things with my new to me 6hp outboard. Recently found I had to replace the impeller (tell tale water was hot and flow was weak). Along the way to dropping the gear case I couldn't get the shift clamp loose because the bolt holding it together was all stripped. I ended up trying to drill it out and damaged the shift rod clamp, a little plastic piece(pictured). I am wondering if someone could direct me to where I could order a new one? Many thanks
I would try Outboards-Direct ( aka Oakley Marine ) :: OutBoards-Direct :: who are Yamaha agents. Google will find you others
Fill out the on line enquiry form and you should get a call back from them
The two halves are listed separately Confirm the full engine details in case there are any variations with age, but I dont think there is
