bccjbn
A very simple question - so simple that I feel foolish asking it.
Is the fuel switch turned to the right or the left to open it?
Some good rules of thumb, taught to me as an apprentice, look at the pipe, if the "cock" is in line with the pipe it is open. Turn clockwise to close something, when looking at it from the operating side. As an aside, taught by the same fitter to me, always fully open a wheel valve and then shut it half a turn. If a wheel valve is open all the way then if you go to open it, not knowing if it is open or not, you can force it and break it. If it is half a turn from open then it will be "loose" and you know it is open.Seemples.
Like Vic says.
Take the cover off. Disconnect the fuel pipe from wherever it goes to (not from the tap, you'll bust it) lower the end of the pipe so that fuel can flow out and turn the tap. In one position fuel will flow. In the other it stops.
Needs fuel in the tank.
Mine is the same as this: http://www.ybw.com/forums/showthread.php?t=278979
I used it today and i'm pretty certain it was clockwise to fuel on
