Yamaha 4hp 2 stroke Outboard Model 4AC Petrol Oil Mix ?
Jim@sea
12 Feb 2010
Glasson Dock
I have a Yamaha 4hp 2 Stroke Outboard Model 4AC.
At sometime in the past it was sold by an outboard dealer as a "Refurbished" Outboard and they put new Stickers on it.
One sticker says 100:1 But when I read a manual it says 50:1. OK I know I can out more oil in the petrol but I would like to know what the mixture should be . Please ?
50-1 .....
Many outboards changed from 50-1 to 100-1 in answer to Green lobbying .... but it was a move that not long after manufacturers reverted to 50-1.
Honest ..... 50-1 - you will not regret it.
50:1 is the safe mix for all premix 2 stroke outboards since the mid 1960s. Before then they usually used an oiler mix
Edit
I should have said most not all . Seagulls being the notable exception.
All ?? There were still O/bds such as Seagulls being produced into the late 60's + with 25-1 ..... but I agree that generally 30-1 and up to 50-1 was common.
In about 1967 or 1968 I bought a new Seagull 40+: the manual specifically said to use lowest grade petrol with a 10:1 mix of straight 30 motor oil, which is what I ran it on for over 10 years, first on a dinghy, then on a small cruiser, sometimes hour after hour at full throttle, pushing a ton of boat. The most reliable and easiest starting engine I've ever owned. But noisy, smoky and oily......
Interesting as I had 3 Seagulls and I was told to run on 20 .. 25-1 ...
The only two downers ..... the flying rope that could inflict serious on others in dinghy ... so I used to tell them to look away and head DOWN !! Second was the fuel valve !!
I guess I should have said most, not all
Seagulls from IIRC 1968 , can be coverted to run a 25 :1 with a change of metering needle or jets depending on the carb. Before 1968 they had different ( smaller ) main bearings which makes then unsuitable .
Towards the end of their reign some models were supposed to heve been suitable for 50:1 .... I don,t think any survived that .
I have converted both of mine ( '73 and '74 models to run on 25:1 ... Makes them a lot less messy
All the history etc is on the SOS website
