gadgetman
I've had a few of these in bits and the water passages are easy to clean with the power head taken off the mid housing and pulling the head off is " normally" straight forwards. Don't split the lower ( crank) housing unless you know what you are doing. There also isn't any need to do this for the cooling issue as there are no internal passages in that part of the engine. Also check the pick up tube for corrosion / holes. I've had one that was eaten through, so when the water pump pushed the water up it, some of it leaked out before it got to the power head. BHG Marine are a good source of Yamaha spares. I would recomend replacement of the gaskets every time as they are. It that expensive.
Good luck
Good luck
