Katouf
I've got a water pump problem with an old (1984?) but little-used outboard that came with Katouf. It starts and runs but now no water comes from the exhaust. It is regularly run in the after-use fresh water tank at the club so salt deposits shouldn't be a problem.
I've followed the threads on the MB forum and am confident that the impellor has died of old age. The problem is how to get at it!
I've undone the two bolts and got the lower casing apart but only about 1/4". I'm reluctant to pull or lever too much (to try and pull the drive shaft from the head or the cooling water tube from its rubber grommet) in case they won't go back.
Thought I'd try going in from the prop end to release the circlip at the bottom of the drive shaft but having undone the top and bottom 10mm bolts, I can't separate the packing gland from the housing - the paint is still new and the joint is well hidden. It's remained undisturbed and unserviced for years.
Should I hit it, lever it apart or what? I've looked at the boats.net/parts website for the exploded drawings (thank you Vic S) but cant see anything obvious. I need to be careful as the part is labelled obsolete! Any ideas?
Alan
Alan
