Snapdragon25
Hi Folks
does anyone out there have any ideas why my outboard - Yamaha F4A 4hp 2003 is being a pain?
It will start relatively easy - doesn't require much choke, but then will not run properly, coughs and splutters, no rev range and just more or less stays on a very rough tickover no matter where the throttle is set!
If I then turn the fuel off or change it to the (unconnected) remote tank position it will start to rev up happily as it runs out of fuel. I have also had the same result if I drop the carb bowl drain plug out!
I have lost track of how many times I've taken the carb off and gone through all the usual cleaning procedures but there are no large lumps of debris emerging.
The throttle cable linkage and choke linkage all appear to be set up properly and the little air control screw doesn't appear to have any effect on the current problem.
The engine has been stood for about 12 months and prior to this it worked perfectly.
i've dropped all the jets out, cleaned them and had a wire up though the various orifices without finding any dead seagulls or likewise so I'm baffled at present!
Anyone got any bright ideas? Please!!
LB
LB
