Yacht transport by road-self laoding crane required.
mickywillis
23 Mar 2007
Epsom,Surrey
Looking to move a Westerly Griffon by road from Ipswich to Langstone.
Can anyone recommend a local company (local to Ipswich or Langstone) that has the facility to self load onto a trailer using a front mounted HIAB crane?
Search facility turns up a couple, but their websites are no longer available.
Need the HIAB to lower and put up the mast at either destination to make things easy rather than using separate companies/operators to do each task.
Thanks.
Getting a bit p8ss*d off with this now!
After emailing about 25 different haulage companies (both boat transport specialists and heavy haulage companies) only 5 have had the decency to reply back to me with either a quote or a "sorry we cannot help you" message.
Part of my current job involves contacting customers regarding quotes for repairs to their equipment.
EVERY single enquiry receives a response.
Why is it the common decency of replying is now a dying art?
Even if a supplier/contractor cannot assist with an enquiry, why do they just not bother replying? Is it too small a job or are they making so much money, they can afford to pick and choose what work they want?
Maybe its time to set up a haulage company!!
This is the way of the world these days. If it does not earn them money then don't do it.
Thanks.
Most in-built cranes on lorries are good for 1 tonne a few for 30 cwt any distance outside the wheelbase.
For a Westerly Griffon, you'll almost certainly need a separate lift crane and a low-loader.
This might account for the number of no responses you're getting - the machine for which you're has not yet been invented.
My Vega (just under 3t) was launched/recovered using a lorry-mounted HIAB.
Westerly Centaur transported using lorry mounted hiab. No problem, just make sure there are spreaders to avoid pinching the gunwales.
DSCF0085 small.jpgView attachment 44449View attachment 44449
My Artekno H323 which weighs 3+ tons was moved by Hiab firstly in North Wales and subsequently on her yard trailer in Northern Ireland
Mate had his Jaguar 25 transported last week by the firm I suggested. Griffon would not be a problem provided the truck can get close the boat to lift.
Try Jeff at the address below, he has fold up lorry mounted crane which will probably lift Charle's 1 ton lorry let alone a Griffon - believe it can lift 7 ton close in - diminshing obviously as further out. Can't see mast being a problem. It won't be cheap tho' so why not sail it ?
Coastal Transport
E R B Buildings, Claybank Road
PO3 5NH Portsmouth
Hampshire
Phone:
023 92352454
Fax:
023 92673871
Hiab disagree http://www.hiab.co.uk/Products/Loader-cranes/?productGroupId=34360
23 tonne metre would allow a fair bit of reach for a 5 ton boat.
There are trucks fitted with suitable Hiabs to lift a Griffon and able to carry such a bilge keeler on their flat bed and remain inside load limits.
We have at least one such company in Edinburgh.
I had a konsort lifted by a friend and it was a decent size inboard hiab but it struggled It might be able to lift a lot close in but just to get down beside the lorry is a 3 - 4 meter reach minimum. (Centre of lorry to side then plus load centre ) and my boat for instance is near on 10 meters long so that is a minimum reach of 5 mts to lift it Of the lorry bed Look at hiab lift chart for 5 ton at that reach thair is lorries with larger ones
