Yacht Surveys - A Christmas Competition.
doug748
1 Oct 2002
UK. South West.
These two videos were pointed out by BurnitBlue in the other place. They show a yacht surveyor at his trade:
And part two:
Father Christmas will deliver a virtual bottle of the finest malt to the winner who spots most errors and half truths.
Part 1
- Only checked cutless bearing for play in one direction.
- Assumes engine misalignment from worn cutless bearing (there are other possibilities)
- Blisters in hull caused by "either epoxy or someone didn't do a good job". Eh? caused by epoxy?
- Suggests they blast whole hull and start again!
- Replace all seacocks and through-hulls based on one bad one.
- "The significance of cast iron (in the hull) is that there's nothing wrong with it". eh? that's the significance?
Part 2
-"you don't want to have snatch blocks". He might not want them but how does he know that his customer doesn't want them?
- "Starving stainless of oxygen makes it brittle"
- Need to rebed all topside fittings coz they've never been done.
- "We're not trying to make a new boat of an old one" (isn't he?)
- "Replace the genoa cars" (why?)
- "All this stuff should be replaced because its the original" (that's not a good reason to replace anything!)
- "you need a windlass"
- "get your windlass from where I get a cut from it" (a beauty that one!)
- confusion on preheat of engine when starting it
- "Get a twin forestay and get rid of that furler"
- "all furlers fail"
- He calls them "Ewes guys"
- Calls the mainsail slides "hanks"
There's more than this though.
He needs a survey on the fly of his jeans that's for sure :-)
Oh … and the prospect owner appears very cheery considering the surveyor is recommending the whole boat is replaced!
Of course. A survey like that is worth its weight, in persuading the seller to knock a goodly chunk off the price.
I just love an over-critical surveyor. The tricky bit is to get him to write a report that is sufficiently convincing to persuade the seller to drop the price; without being too over-specific so that when you have bought, the insurers insist you undertake costly remedial work.
I've seen survey done like that. Focusing on irrelevant things, condemning various things on whims. Missing out on some functional stuff? Then producing a written report stuffed with as many caveats at possible and little substance (and perhaps a 50% cut &paste). I have seen a straight professional survey done as well - a world of difference.
