Yacht hits container
25931
22 Aug 2008
Portugal-Algarve
I've just read in a Portuguese newspaper that an English yacht was damaged yesterday afternoon near the coast between Albufeira and Portimão when it hit a container. It appears that the only occupant took to a rubber boat and was rescued and the yacht was towed to Portimão. The authorities will be looking for the container.
uxb
30 Sep 2008
Up high
I wonder why he got off- seems the boat was just fine.
Reverend Ludd
15 May 2011
Great Yarmouth, Norfolk
I was on night watch going down the coast of Portugal and saw a strange triangular thing slip by about 10 or 15ft away.
I did a double take and realised it was the corner of a container, there was no way I could doze off after that :eek::eek:
Seajet
23 Sep 2010
West Sussex / Hants
Containers; money talks !
I do think semi-submerged containers are the 'elephant in the room' threat, and may be the answer to several mystery sinkings / disappearances, including Mike Birch in 'Three Cheers', and there's still a question mark over the cruising catamaran capsized after possibly hitting a container off Ryde...
However container ships are big business, aren't they ? :rolleyes:
Evadne
27 Feb 2003
Hampshire, UK
So shouldn't the spec be that they sink in a certain time with trackers on anything containing hazardous material?
A container will fill with water and sink unless it's full of anything that gives the whole package a density of less than 1. Waterproof, they are not!
Blueboatman
10 Jul 2005
When I crossed the pond I seriously thought about having a (spinnaker type) pole projecting a metre plus in front of the boat, and hanging not one but two of those V prow fenders on the stem, which 'might' reduce the possible contact area with strange objects like ships..
D
Deleted member 36384
You could use one of the large round fender types. By feeding a line through the pole you could pull the fender eye up tight and this secure a large soft ball ready to butt any object. If it was a pink fender you could nick name it the The Swan.
A collision bulkhead would be better, but where to put it?
rogerthebodger
3 Nov 2001
Shipping containers are not the only thing that falls off ships at sea.
Have you seen how tree trunks a carried and if tree trunks fall off a ship they will take a very long time to sink and are as dangerous as containers to yachts at sea
Seajet
23 Sep 2010
West Sussex / Hants
There was a proposal years ago to fit containers with salt blocked vents, so they might sink relatively quickly; I'm not sure what the financial argument over-riding it was, but I couldn't help thinking it would be preferable to prevent the things going over the side in the first place !
When we were conducting recce camera trials on the Sea Harrier aircraft, Test Pilot Mike Snelling took shots of a ship off Shoreham in a gale, with large planks washed overboard all around her; he had an interest, as he also ran a fishing boat out of Brighton.
Any of those planks would have made short work of the average yacht, I quite fancy the idea of a watertight compartment in the front ( at least one Anderson 22 has this ) but it's quite difficult to organise what with access & ventilation for breathing etc.
I was told of certain Services training boats which were so effectively water/ air tight the crews in the forepeak nearly suffocated ! :rolleyes:
Blueboatman
10 Jul 2005
Plan B. I did compartmentalise everything up to bunk height and had tiedown strings to hold the compartment lids on. Whilst not totally watertight at all, the theory was ( as proved with any wee deck leaks too) that after the BANG of a collision, the extent and whereabouts of any hull stove in area would be v easy to find and , hopefully, then stuff that compartment(s) with rag/teeshirts/plastic tarpaulin/stuff to act as a coffer dam and buy time for the second, better repair.
Seeing a rising bilge full of water is spectacularly unhelpful when you cant locate just where the damage might be..
