Talking about pots and fishing behaviour, I wonder if the forum has any comments on this experienced.
I was drifting down towards Berry Head from the south. About 200 yards ahead was a circa 35ft fishing boat laying pots. There was a pot some way off to port, one fine on the port bow and the fisher moved off about 40 yards or more to starboard where he laid/tended to other pots. I had scant steerage and was drifting with the tide. When I was about 20 yards away from the pot close to port the fisher opened up and started to circle. I suddenly realised that the pot I was watching suddenly had a 10 knot tide rushing past if and it was rapidly moving to starboard. Then the other pot to port started moving. I realised, of course that the pots were linked in a daisy chain and the fishing boat was towing the whole string across my bow.
Having circled and virtually enclosed me he then headed straight for me and hurled a tirade of abuse about yachties getting in his way. Was I stupid not to realise the whole string of pots might move as one, and if so how, with my engine stowed and 0.5 knots of boat speed plus a knot of tide, I should have avoided his gear?
Yes, but instead of getting embroiled in argument, what you need is a fitted rope cutter.
This is the first time I've come across a string of pots - presumably all on the sea bed, being towed as a unit. It seems a strange and damaging operation.
I would review what you do with your engine while under sail.
I would not personally want to be in a position where I could not just fire up the engine to get out of trouble.
My OB lives on a bracket on the transom that can be raised to get it out of the water for sailing, but it's only a few seconds to lower it and start it.
Are you sure they were pots? I'm no fisherman, but it sounds to me more like a net being drawn around a shoal of fish (which you happened to be directly above).
That's a good point, Pete but each buoy had it's own marker and was clearly intended to be lifted independently, so I presumed it was because there was a pot at the end which would have needed emptying from time to time.
Think it is more likely to be a net and the marker is to show where the net has been laid. Pots are usually laid in strings with only one marker buoy which is the pick up point for lifting the whole string.
