jimi
To clean the filter on the front bilge pump under the cabin sole I had to unscrew the eberspacher outlet and the doorstop before I could lift the sole .... aaarghhhh!
Imagine you're hard on the wind, and it's a bit choppy.
How would you carry cups of tea from that galley to that cockpit?.
Gentlemen don't sail to windwardUnrelated to that issue, but here's the work of a bonkers yacht designer:
Imagine you're hard on the wind, and it's a bit choppy. How would you carry cups of tea from that galley to that cockpit?.
Gentlemen don't sail to windward![]()
How to turn off the inlet seacock in our heads, c/o German Frers.
Enter aft cabin
Pack bedding away
Raise bunk cushion and move it aside
Raise section of bunk base and place carefully somewhere in case there is any oil on it
Switch on light
The seacock is somewhere there.
That's not a wine rack, it's a purpose made storage rack for the full set of code flags the owner carries on board.With that pitifully small chart table I suspect this is designed for fair-weather coastal day cruiser types. And is that a wine-rack on the left?!
