I know that many of the carbon spars on classic sailing yachts have been very cleverly painted to make them look like timber - this might be an easier option than trying to bond a thin layer of timber on to the carbon mast?
Your limiting factor here is the ability to clamp the veneer to the mast uniformly, so that all parts of the veneer are under equal pressure. Vacuum bagging is the only method that I can think of right now which would do this, and the number of companies set up to do this on the scale that you are obviously thinking of are very few and far between. Be prepared for costs that look like telephone numbers!
Peter.
I think the guys who were racing Griff Rhys Jones' boat who had an identical type of yacht had a painted carbon mast instead of a wooden one - looked great, couldn't tell /forums/images/graemlins/smile.gif
I'm thinking of using 1" Douglas-fir strip planking with round edges to cover a 50' mast. I would use Sika between wood and carbon and epoxy (or something more UV resistant) between the strips of wood. Bronze mast fittings would firmly hold the wood at the deck level, gooseneck, spreaders and stay attachment rings. The question is should I use Sika between the wood and carbon or nothing to allow more movement between the two masts. Or is this a very stupid idea?
I'd have thought the carbon mast is carefully designed to flex in a certain way, and a certain amoount under loading. Certainly that's the best way to use carbon. The problem you'll likely have is a difference in the flexing between the wood and the carbon.
If you glue the two together, you'll be putting the glue under stress each time it flexs. If they are seperate, then you have one moving over the other, possibly abrading the carbon. You may also end up causing a "hard point" in the bend characteristic of the carbon mast that would quickly weaken it.
You'll also be adding lots of weight at a large rotational moment that is not needed.
I'd go with the paint, or possibly very thin laminates - 1 or 2mm thick.
If you're going for inch thick Douglas fir, you're most of the way to a wooden mast all in it's own right anyway! Forget about the carbon mast and just get a wooden one!
Or as Big_Southern_Jesse suggests, get a decent wooden mast. A well built hollow Sitka Spruce mast will be stronger and lighter than it's aluminuim equivalent.
The reason for having a carbon fibre mast is to save weight aloft. By sticking 1" thick timber on it you are cancelling out that advantage. When you glue two different materials together it is important that only one of them has the strength; the other one has to conform to the strong one. By having carbon fibre and 1" thick timber you have two competing media, each wanting to have its own way. While Sikaflex may stick to timber quite well, i would want to see some impressive test results of its adhesion to Carbon fibre before I would have a bar of your proposal. Paint it; it will be cheaper and more durable.
Peter
I dont know if its much of a comparison, however, most wooden floors in television series are really just paint on a resin floor - there are even special machines to create this look. The resolution is obviously much less than the human eye, however if more time was taken, a really good finish could be achieved.
I agree with everything said so far. If you really want something better than paint, a thin veneer of softwood vacuum bagged on with epoxy resin glue is the only safe engineering way to go. Putting enough wood on so that it contributes to the structural loading really is asking for trouble even if the glue line is adequately strong. By allowing the two components to creep between hard spots(deck, winches, gooseneck, hounds, halyard attachments etc) will cause failure.
You have a point here, my main objective is to save on weight but i feel that such composite is going to be a disaster on a long run. Maybe veneer would work, but someone has raised the question of clamping veneer on a carbon mast. Thank you for suggestions!
On the weight saving front, I saw a tourist boat in Portimao that got the wood effect by wrapping Fablon round the steel mast. What was left at the top they had scrunched up and shoved in the open hole. Well, it was cheap, and looked vaguely authentic at 100ft away................
A
