johnegraham
New Member
I want to buy a Spade or a Rocna anchor for my Contessa 32. The problem is that the largest model which would fit is a 22lb Rocna (which is the recommended model for a Contessa) and I have been using a 35lb CQR. A friend of mine has a Sadler 32 and has faced a similar dilemna; he has chosen to go the Rocna route. I have always believed that weight is important and read that I should use an anchor one size bigger than the manufacturers' recommendation . Though the surface area of the Rocna blade is a little greater (and therefore should provide better holding) than the CQR, the shank is shorter (probably not a relevant factor) but the anchor is only two thirds the weight. Forumites who have commented on their new generation anchors seem to have been able to buy an anchor of similar or greater weight to the model they replaced. Is ‘heavy good’ or is it irrelevant?
