Pagetslady
My thoughts (with a 50 foot boat).
1. Changing to fully vertical battened main made a huge difference. The sail sets much better and therefore performs better,
2. A main made of the "right" sail cloth that isnt tired makes a huge difference. The cloth is slippery and furls much better,
3. Make sure it is properly rigged (plenty of threads on that). Again a huge difference,
4. Always keep a little tension on the outhaul when you furl - all but eliminates jams,I
5. Take as much pressure off the sail when you furl.
Wouldn't fancy dropping mine with battens in but I guess it is possible, I have had inmast for 25 years the last 10 years I have had Maxi roach which was second hand, which was great never a Jam I have just bought a Crusader battened main it certainly furls well and comes out equally as well it has much thinner battens but would be difficult to remove at sea.
I will know more about the new sail when I have had it longer, my boat is a Westerly Corsair 36 had her since 1992.
Mine is brilliant. No problems having taken these points on board. From a safety point of view it has huge benefits. Keeps crew in the cockpit and off the deck.
Finally if it does jam or breaks have a plan. If it breaks partially furled it could be a problem but inevitably if you can get the thing unwound its not too much of a problem dropping it to the deck - well as much as any sail the size of mine at any rate.![]()
