Snowgoose-1
Easier tacking and would doing away with 90 degree turning block and going straight? Thanks for any experiences .Looking for an easier life when sailing solo
Yes sheet must arrive at the winch from an angle lower than the winch. Not always easy if you have a stand up block for jib sheet. You might need to raise winch or lower sheet in the block. ol'willThe straighter that the sheet runs from the car to the winch the better. Obviously one has to make sure that the sheet leads on to the winch such that one does not get overriding turns- As mentioned above. But the less deflection in the sheet the better.
Going round a 90 degree turn before going on to the winch must add to that friction.
