geegrrl
My ALDE gas detector bubbler was showing bubbles. I was unable to find the leak so bought this handheld gas detector which is said to be very accurate. http://www.amazon.co.uk/Honeywell-Sense-Hand-Held-Detector/dp/B008ASXV8W
The detector gave a medium signal in the grill area of the oven. So I shut off and unhooked the lpg bottle. Then I tested the area in the locker where the lpg bottles reside and got intermittant high readings. There are 2x 15kg butane bottles in there. Neither are hooked up or turned on. The readings are intermittent and I can only assume some gas leaked out from turning the bottles on and off a few times for testing.
I'm guessing the grill is leaking . But why am I getting readings in the locker once the gas bottles are closed and unhooked?
Should I be worried? The BSS inspecter passed my gas setup a few months ago.
