gordmac
Would go for more or less top dead centre.
.....one piston at a timeWould go for more or less top dead centre......
I would have thought they were pretty normal for an engine of that age. You will get slightly higher readings when you put oil in the bores and seal the pistons better, but its a pretty old design which has seen some use so you cant expect high readings. 95 psi is almost a 7:1 compression ratio and back in the 80s even 4 stroke cars were only 9 or 10. Two strokes are always lower.Thanks so much for all your help and advice guys,
Just ran another test. This time engine was cold and throttle open but i sprayed some 2 stroke oil in both cylinders and the readings i got was 95PSI on both cylinders. So compression is slightly rising when oil is in. Can anyone tell me is this a good or bad thing and would my readings be sort of normal for a 40year old engine?
Does the engine work? If so, dont worry. Just get on with life.
Now you have got that far pull the barrels and see if the rings are stuck or worn.
If oil flows past the rings that quickly, air will have no chance. No wear lip at the top of the bore? I suspect without more dismantling you maybe need to scrap it.
Another thought, if the oil is flowing away so quickly I would have expected lower compression than you had, maybe the carbon you disturbed was a good part of the seal? Maybe re assemble with the old gasket (use Hylomar or similar on it) and see where you are?
If the bore still has good cross hatching just suck it up and remove barrel /body and check ring clearance. It's an easy enough job and chucking motors for want of rings is simply barking. Whoever advised sealing the head with hylomar needs a public whipping. That is an almost guarantee of ruining your motor as it never sets and is truly superb at one thing, blocking oil and water passages.
I always used Hylomar on the head gasket on my road and competition engines, as advised to do by the works guys.
The bores didnt look like that! They where sort of smooth polished surface, no gouges or cracks just smooth like it had been machine polished. I did not use hylomar as it stated on the description of gasket that no need to use such products. Anyhow i replaced gasket and still got 80PSI on both pots. Think bigger rings are needed as fogging oil leaked past pistons within minutes. Thanks
Sadly I think your engine has run it's course. You need crosshatchings to retain oil for lubrication especially in a 2 stroke and without cross hatchings you should expect even higher compression readings. The bores have been worn alongside the rings and although you could put in oversize rings the engine would likely need a complete top end rebuild and it may not be financially viable.
Would you say the increase between hot and wet test is cause for concern or is this pretty normal and also is 105psi hot acceptable or is there still an underling issue? Thanks folks
105 psi hot is acceptable but no cross hatchings is still a concern as the cylinder is not effectively lubricated. There is a chance the bores are glazed and a good clean may reveal some hatchings still, or you could have them professionally redone, forget scotch bright pads the angle is important and if the barrels are nikasil it will need specialist tooling.
For cleaning glazing dont be tempted to use abrasives. Use a cloth and clean first with brake cleaner and then with ATF (it's also a good detergent and will pick up where the brake cleaner left off.) Then run the engine under hard load with Seafoam. You may get lucky. Sea Foam 1 Pack (16 Ounce) Extreme Marine & Rv SF-16 Seafoam Liquid 16 Fl Oz: Amazon.co.uk: Business, Industry & Science
