worn cutlass bearing
smeaks
31 Aug 2003
tyneside
During pre purchased survey it was noted that the cutlass bearing was worn and had some play (about 1-2mm) I had to get the boat launched and back home and was advised the wear would not cause a big problem but should be addressed when next out on the hard. This advice proved sound and the boat (Moddy 27) performed well underpower since. She has resided afloat with the odd winter trip out and it was my intention to sail her through this season and lift her at the end of the autumn addressing all hull issues (new log etc, cutlass bearing at that time) the only signiture i get that the bearing is worn is a little vibration espesically evident when motoring in a swell.
Will this cause me a big problem if left through this season (I am unsure of the consequenses of leaving it) or would it be better to bite the bullet and pay for a dedicated lift to replace this item at this end of the season?
thanks for your input - smeaks
Mine has been like that for a couple years now, if not worse. Wait until you are on the hard with plenty of time. You might have some shaft wear as well which you may also think about replacing .Best thought about in slow time rather than in a hurry in the summer.
To be onest it is less of a vibration more of a slight rumble when the engine is at about 80% throttle and the load changes on a swell. That is why i put it down to the worn bearing.
