Tam Lin
I used iroko and made a steamer out of a wallpaper stripper steamer and a piece of down pipe. Worked ok.
JD, I’ve got some good lengths of t&g mahogany flooring you can have. Just needs planed to size. I used it to make new gunwales for my 6’ prom dinghy using the hot wet towel method.
I used Iroko when I did the toe-rail of the big boat. Scantlings were around 55x18 one part vertical and one flat on top. The vertical one also had to conform to the curve in the sheer while the top one needed to follow the deckline, 'bent on the flat'. Both were done without any steaming. You do need a lot of cramps though; I was using around sixteen, walking them along as work progressed.
On the tender, 205cms long, I used two layers of 6mm ply, inside and out, laminated in situ with recorcinol glue. However, the ply is protected by a rope fender that goes all round. I built the tender in GRP (pseudo clinker) but I wanted the 'sheer strake' covered with varnished wood.
Whichever solution you choose, both are good and easily doable... given sufficient clamps.
