Bobobolinsky
I used Iroko for the gunnels of my dinghy, real mahogany is difficult to come by since the import ban and sapele and maranti are not as stable around seawater. I got a plank from AC timbers at Ely 38mm x 150mm x 3400mm for £34 inc. I did get a local woodman to rip it for me, this was for several reasons, Iroko as has been said is an oily wood and grabs the blade (especially if like me you don't use a riving knife on the table saw), I'm a long way down the yard and the voltage drop would kill my saw cutting iroko.
You won't need to go to the expense of structural fillers, the bond is more likely to fail on the foam core than the epoxy. If you don't have enough clamps, you can screw into the first rail and then remove the screws once cured, a dip in wax is enough to allow the screws to come out again.
Oak turns black (actually a very dark brown) with epoxy because of the iron content. I think you will have a major problem putting on the capping rail, as it is going to be a wide piece of timber. maybe better to fit in two pieces and band saw the curve, just a thought. There is a guy who's name eludes me but advertises on the Canadian Canoe Forum who sells epoxy at a reasonable rate.
