Murv
Is there anything on the market that can be sprayed, or brushed, onto steel that still has diesel residue on it?
There is a possibility there is a pin hole somewhere along the base of the tank, so before I go in with the wire brush and CT1, is there anything better out there?
The tank cannot be removed, nor can I get to it well enough to solvent clean it properly, so it needs to be something that meets the criteria above.
It's also a fairly large tank at around 550 litres so small patch kits probably wouldn't be viable.
I very much doubt there is anything, but doesn't hurt to ask!
