fireball
We've often had a little stab at countering the (often silly) scenarios our Mobo friends find themselves in ... usually of their own doing ... so ...
Wot know Skip?
Your boat is a Fin keel Sadler 29, tiller steer, slab reefing main (all controls at the mast) and roller genoa. There is just 2 of you onboard.
You're midway on passage between two headlands - and around 7Nm from nearest shore. It is a close fetch, so a quick run has seen some cracking sailing, however the wind is picking up and the current full sail is getting too much, so you decide to take a reef in.
You carry on helming whilst your crew eases the main and then goes forward to the mast to put the reef in. 1/2 way through the reefing procedure you get caught by an unexpected wave (probably a passing mobo /forums/images/graemlins/wink.gif ) and crew topples over the side - he's only been 1/2 a plonker because although he is wearing his lifejacket, he didn't clip a lifeline on...
You're now left with a mainsail with cleated halyard, but reefing lines loose, full genoa and no tiller pilot ... WNS?!
Wot know Skip?
