Paddy_N_Murphy
Spurned on by the thread about making a homemade panel, I have wondered if anyone here would mind me seeking advice on a Wiring installation on a .......................
Horse Lorry....
(I am a frustrated sailor landlocked in the North, with a wife who rides !)
Think of it like a boat if it makes you feel better !
Essentially the same scenario though eh? The Engine & Engine batteries are the Golden Egg and to be preserved at all times from draining, the rest is fripperies and toys ?
Judging by the sparks given off when we tried to 'review' the existing system and the odd flat battery we have had for no reason, I am assuming Ray Charles and Stevie Wonder put it together.
Anyway - My Plans / Hopes are :
IP rated 240v Inlet hard wired in feeding a Consumer Unit.
Consumer Unit feeding a 240v / 24v Charger Booster, the 240V Fridge Circuit, and any Aux 240V Sockets.
The Lorry Alternator and above Charger are in turn is connected to the two Battery Banks (Lorry Engine / Lorry Living) Via a Split Charge Diode http://www.the12voltshop.co.uk/Shop/split-charge-diode-70a-ste-d70a2.html (the bit I am concerned about TBH.)
From there, One split goes straight back to the Lorry Batteries via an Isolator (currently on +ve, I will hopefully swap to the -Ve)
That should have the Lorry isolated from all other Drains than the lorry itself, yet charge all Batteries whilst driven, and giving the ability to charge all batteries if hooked to the Mains via the Shore Supply. BUT better still, by switching the Charger to 'Boost' giving an 18A output, I can jump the Lorry from the Mains or the Generator we have so the OH could easily get going again if stranded rather than worrying about Jump leads / Sparks etc..
OK - moving over to the other side of the Lorry - the Leisure Batteries are isolated too, and power 24V supply to the Diesel Cab Heater, the General 24V Lighting, and a 12V Dropper to Power the Tri-Source Fridge (240V/12V/LPG).
Thoughts, Opinions, (cares??!)
I KNOW a better job can be done, and a better spread of bits and pieces could be used, but it will escalate to Hundreds and Hundreds unless I do it myself with all of these bits and pieces I have 'collected'.
Horse Lorry....
