demonboy
I have a couple of problems.
1. The first is that my schematic I drew before taking off my Lucas 50amp. alternator has gone walkies, so now I am left puzzled by the rewiring of it. The two labelled terminals are 'B+' and 'W'. Confirmation of the following points would be appreciated:
- I have the positive which will go from terminal B+ to my new Sterling split charger.
- Then there is a negative which comes from the starter motor, which I think was attached to the body of the altrn8r - does this sound right?
- A third wire must be my ignition
- I have a fourth thin wire that I simply cannot trace. Any clues?
- Was 'W' field? Where does that go?
2. I'm having a new Lucas TVS 90amp altrn8r fitted but the back of it looks nothing like my old alternator. From what I can see there is only one terminal, which has to be the positive. There appears to be a couple of small terminals surrounded by a plastic casing which looks like it should be a plug of some description.The alternator man here assures me he can bypass the internal regulator when my Balmar gets delivered but said it is constructed differently to the old alternator, which makes me nervous somewhat! This is obviously an automotive alternator so have I made a mistake in buying this, or are the terminals there but hidden? Is my paranoia justified or does this new alternator sound ok provided it is moderated correctly?
