damo
Having just decided to bite the bullet and lift the engine to refurbish the engine compartment and stern gear, I got a nasty shock when stripping out the wiring. The cables in the engine wiring loom, which has probably been untouched for 25 years, and wrapped in spiral wrap, have spiral grooves where they have been working against each other, presumably due to vibration. Some cables were worn through and the cores were exposed: short circuits waiting to happen.
I will wrap each new cable first before bundling them when I refit, but does anyone have an easy solution for chafe protection ie material that is oil and heat resistant, flexible and cheap. Or is plastic spiral wrap on each cable first the obvious solution?
