SimonA
I'm installing a 100w solar panel and MPPT charger. The wiring from the charger to battery is 12 AWG, I need to fit some crimp lugs to the battery end of the cable bit am confused as to what size I need for 12 AWG wire.
Crimp lugs seems to be sold using various ways of measuring them. I've found 12AWG is 4mm2 and 2.053 diameter according to a chart on the web. I need lugs with a 10mm hole for the connection to the battery. What size lugs do I need for the 12 AWG wire and should they be the heavy duty uninsulated type, or can I use the yellow insulated type?
