stevebrassett
I have just invested £40 of my hard-earned dosh on the recommendation of posters on here on one of the 3-socket leads. I want it for both boating and camping. Not used it yet but it looks a well-made piece of kit.
What is important, and not necessarily made clear in advertisers spec's, is that protective device has to be double pole for campsites and marinas (so the it interrupts both line and neutral if it trips). Additionally, it is desirable, but not essential, that RCD has a lower trip current than the supply socket that it is plugged in to (supply sockets typically use 30mA RCD's). Then the user one should trip before the supply socket one trips.
This then is where a garage consumer unit falls short of the requirements in having an RCD and two SP MCBs . It would have to be installed in conjunction with a DP Circuit breaker in the incoming supply.
Even that would not achieve the intent of the requirement because the SP device could trip without the DP device tripping. All protective devices (overload or RCD) need to to interrupt both L and N.
(whether or not you consider this overkill is a different matter)
Maybe what I am doing is wrong but I have a 'smart charger' which, when in the marina, I simply plug in to a shore line which has a standard double household 3pin socket at the end of it. This charges the batteries, powers the whole 12v circuit and has one spare 240v socket for if I have anything else to run. I leave this all attached when away from the boat to keep the batteries in good nic.
I use a bep battery monitor which has a shunt to monitor amps capacity. I mostly use the volts function. I should get an RCD for my shore power cable.
I have not seen the latest version of Iso 13297 but the previous version only required DP circuit breakers on branch circuits on non-polarised systems . SP circuit breakers ( or a fuses) were all that was required on polarised systems.
A DP circuit breaker was required within 0.5m of the input connection in both cases.
Are you suggesting that this has changed in the new edition and that DP circuit breakers and switches are now required in all cases .
I think there is a misunderstanding here, There is no absolute requirement for a circuit breaker within 0.5m of inlet in the current or previous version of 13297.
Branch circuits from the distribution panel in polarised systems only require over current protection on the active phase, DP are not required.
Most garage units, in fact I think all supplied now are equipped with a DP RCD, I don't recall the last time I fitted an active phase only type.
7.2 Main supply circuits
7.2.1 Double-pole circuit-breakers shall be installed in conductors to the shore-power supply circuits.
7.2.2 A manually reset trip-free circuit-breaker shall be installed within 0,5 m of the source of power
This is what I am quoting re the requirement for a DP circuit breaker within 0.5m of the inlet
It does go on, admittedly, to say, "if impractical, the conductor from the source of power to the panel-board circuit-breaker shall be contained within a
protective covering, such as a junction box, control box, enclosed panel-board, or within a conduit or cable trunking or equivalent protective covering."
with further qualification and requirements if the distance exceeds 3m
Are there any differences between the above and the new version of ISO 13297 which we should know about.
I'm about to install one of these:
http://www.power-store.com/view-item.asp?itemid=245&id=45&
Not the budget option but I beleive the one of the easiest ways to install a safe system.
