PaulRainbow
Except that as the battery charges the current will reduce. You may have 3% volts drop at the max charger output current but as this reduces so will the volts drop . By the time you have reached say 5 amps it will only be 1/5th of what it was at 25 amps. Approximately 0.086 volts. At lower currents it will be even less.
This is why the Ctek chargers will work even though the battery connecting cables are relatively small compared with what you calculate to be necessary if you base your wire size calculation on the max charger output.
The Ctek chargers are basically compact portable chargers for which having several metres of AWG 4 or AWG 6 as battery connections would be a complete nonsense. The cables would be bigger than the charger.
I thought I had already explained this.
Just because you have offered an explanation that does not mean that it's correct, it certainly doesn't mean that it's correct for all chargers in all installations. To even type that smacks of arrogance.
The Ctek charger is closer to 6% loss at max output.
Anyway, what has the Ctek charger got to do with anything ? It's just a red herring thrown in to justify suggestions of light weight cabling. We don't even know what the OP has.
I have thicker cables going to my Sterling charger than the Ctek and my cables are less than 1m long.
