Wire size recognition
Daydream believer
6 Oct 2012
Southminster, essex
2 questions here
I want to wire in my new chart plotter plus my AIS ( NMEA183 wiring)
I am considering using Wago connectors instead of the choc box connectors, with bootlace ends on the wires, that I used in the past.
However, I am not sure what Wago connectors to buy, because I have no idea what size wiring I have. I think Wago do a range of sizes dependent on wire diameter- is that correct? I am also worried that with very thin wires the Wagos may just cut through the wires, if there is any vibration- Is that an issue?
Will Wago connectors be OK with very thin wiring, or should I just solder together & hope I do not have a maintenance issue, or should I use bootlace ends & stick with choc box connectors? I would prefer the ability to disconnect when needed, without soldering, away from home, if I have an issue
I would assume (& we all know what assumption is!!) that if I go to somewhere like Screwfix I will get those most suitable for household diameter wires. - Will I?
Have not tried yet!!
So as a general query, not just about this particular problem,. If I pick up a piece of electrical wire, how do I determine its sizing? Just saying it is XAWG or Xmm2 means nothing to me, because I cannot calculate the cross sectional area very easy.
How do I determine the AWG of a very thin wire ?. The wires on my AIS are so thin they almost break if I look at them. Can I put my Micrometer across the diameter & tell from that?
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I've been using the WAGO 222-412 connectors (the ones with an orange lever) to connect cables. They cover sizes 0.08 to 2.5 mm square cables and seem to grip data cables well. I'm using them to wire in my AIS. Much easier than choc blocks.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
For sizes, look on the WAGO website.
To get mechanical strength on thin wires you could heat shrink several wires together at the entry point to the connector.
With the old choc block I used to fold thin wires back along the insulation and clamp wire and insulation together to get mechanical strength. I'm not sure if you can do that with WAGO.
PaulRainbow
16 May 2016
Suffolk
2 questions here
Good plan :encouragement:
Your wiring will usually consist of mostly of 1.5mm and 2.5mm for general wiring. NMEA 0183 wiring can be .22mm or a little thicker. N2K is thicker.
The Wago 221 series will take wires from 0.14mm to 4.0mm
https://www.wago.com/global/electri...stallation-terminal-blocks-and-connectors/221
Not an issue, the Wago connector clamps the wire, it isn't an IDC connector.
No choc blocks, please :ambivalence: You can of course solder and heat shrink, but if you want to be able to remove them, the Wago is a good solution. When i fit chart plotters at the helm, for instance, i stick some Wago connectors in the back of the helm pod with some quick drying epoxy and use those for NMEA 0185 or power connections. I don't like to see the connectors just dangling around, so stick them in place, or cable tie the wiring securely close to the connector.
Screwfix stock Wago 221 connectors.
Lots of online calculators, such as https://www.rapidtables.com/calc/wire/awg-to-mm.html
PaulRainbow
16 May 2016
Suffolk
I used to use those, but the newer 221 series is smaller and neater, the levers require much less force and they take wires up to 4mm. There is also a version of the 221 that will take up to 6mm wires.
Zing
7 Feb 2014
I sometimes use gel filled telecoms connectors by 3M, especially if there is a chance of moisture being present. They are designed for thin wires.
lw395
16 May 2007
If I really want to know the AWG size of some wire, I have a pair (well, several!) of wre strippers with multiple slots in the jaws calibrated in AWG and/or sqmm.
My crimper is fairly tolerant of AWG size on bootlace ferrules, so long as you don't use a stupidly big ferrule it should pass a reasonable pull test.
Daydream believer
6 Oct 2012
Southminster, essex
I believe (I stand to be corrected) that Wago do a moisture resistant sealant for use with some of their connectors. But if not available, would not a smear of Vaseline do the trick, or does it degrade & cause more problems than it solves?
Zing
7 Feb 2014
You can measure its resistance per foot and look up which size is the closest.
PaulRainbow
16 May 2016
Suffolk
If you need waterproof joins, use waterproof connectors. For single wires it's hard to beat glue lined heat shrink connectors.
